Salta al contenuto principale
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
Cosa ti serve
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: passo 1, immagine 1 di 1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 2, immagine 1 di 1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, immagine 1 di 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, immagine 2 di 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, immagine 3 di 3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 4, immagine 1 di 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 4, immagine 2 di 2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 5, immagine 1 di 1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 6, immagine 1 di 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 6, immagine 2 di 2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 7, immagine 1 di 1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 8, immagine 1 di 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 8, immagine 2 di 2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Conclusione
Giancarlo Marruffo
Membro da: 09/18/16
2 Reputazione
1 Guida realizzata
Pasco Hernando, Team 5-1, Prince Fall 2016 Membro di Pasco Hernando, Team 5-1, Prince Fall 2016
PHSC-PRINCE-F16S5G1
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,092
