Salta al contenuto principale
Introduzione
This guide is for owners of the Fiat 500 Abarth who are unsure about how to replace the rear taillight and the bulbs within it. Taillights are extremely important and legally needed in most places, so it is always important to ensure that yours are always working. When a bulb burns out, you lose one of your lights that tells other drivers what you are doing which can be very dangerous on the road, so it is best to fix them as soon as possible. Many people are unsure how to replace burnt-out bulbs on cars, so this guide is to help some of you figure that out and get back on the road safely. With this guide, you will be able to get a good understanding of what parts and what tools you will need to successfully complete this task. You do not need much for this project other than the tools provided in the details, along with a new replacement bulb for the light that has burnt-out. There are very few hazards in this process, however the biggest advice to offer is to take each step slowly and carefully, making sure you stick to the directions as much as possible. To add on to that, make sure to read through the directions fully before starting, and read each step all the way through before beginning that step to ensure you are aware of what you need to do and what warnings the step is advising. This is a straightforward process that anyone should be able to complete with little issue. Time to get started on the project!
Strumenti
Ricambi
Nessuna parte specificata.
  1. Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: passo 1, immagine 1 di 2 Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: passo 1, immagine 2 di 2
    • Remove the two 10 mm bolts to the side of the taillight.
  2. Fiat 500 Abarth Taillight Replacement: passo 2, immagine 1 di 2 Fiat 500 Abarth Taillight Replacement: passo 2, immagine 2 di 2
    • Using a pry tool or something flat, carefully get in-between the light and the car and pry the light off.
    • The light still has cable connections to the car body, so be sure not to rip these during removal.
  3. Fiat 500 Abarth Taillight Replacement: passo 3, immagine 1 di 3 Fiat 500 Abarth Taillight Replacement: passo 3, immagine 2 di 3 Fiat 500 Abarth Taillight Replacement: passo 3, immagine 3 di 3
    • There are several little clips on this module.
    • Unclip the clips on the back of the light and remove the panel.
  4. Fiat 500 Abarth Taillight Replacement: passo 4, immagine 1 di 3 Fiat 500 Abarth Taillight Replacement: passo 4, immagine 2 di 3 Fiat 500 Abarth Taillight Replacement: passo 4, immagine 3 di 3
    • Remove the burnt out bulb by pulling it out from the panel.
  5. Fiat 500 Abarth Taillight Replacement: passo 5, immagine 1 di 3 Fiat 500 Abarth Taillight Replacement: passo 5, immagine 2 di 3 Fiat 500 Abarth Taillight Replacement: passo 5, immagine 3 di 3
    • Clip the panel back onto the light and put it back into the frame of the car.
    • Replace the two bolts with a 10 mm socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 66
Ultimi 30 Giorni: 248
Tutti i Tempi: 5,099
