Salta al contenuto principale
Fender Starcaster String Removement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Fender Starcaster String Removement, Loosen the Strings: passo 1, immagine 1 di 3 Fender Starcaster String Removement, Loosen the Strings: passo 1, immagine 2 di 3 Fender Starcaster String Removement, Loosen the Strings: passo 1, immagine 3 di 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: passo 2, immagine 1 di 2 Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: passo 2, immagine 2 di 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Removement, Remove the Strings from the Bridge: passo 3, immagine 1 di 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: passo 3, immagine 2 di 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: passo 3, immagine 3 di 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Linea Traguardo
Pasco Hernando, Team 5-3, Prince Fall 2014 Membro di Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,363
