Salta al contenuto principale
Fender Starcaster Bridge Replacement
Cosa ti serve
  1. Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 1 di 3 Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 2 di 3 Fender Starcaster Bridge Replacement, Loosen the Strings: passo 1, immagine 3 di 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 1 di 2 Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: passo 2, immagine 2 di 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 1 di 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 2 di 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: passo 3, immagine 3 di 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
  4. Fender Starcaster Bridge Replacement, Bridge: passo 4, immagine 1 di 2 Fender Starcaster Bridge Replacement, Bridge: passo 4, immagine 2 di 2
    • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
  5. Fender Starcaster Bridge Replacement: passo 5, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 5, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 5, immagine 3 di 3
    • To remove the springs from the bridge, grip the end with pliers and pull up.
    • It is safe to use the body of the guitar for leverage.
  6. Fender Starcaster Bridge Replacement: passo 6, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 6, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 6, immagine 3 di 3
    • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
  7. Fender Starcaster Bridge Replacement: passo 7, immagine 1 di 3 Fender Starcaster Bridge Replacement: passo 7, immagine 2 di 3 Fender Starcaster Bridge Replacement: passo 7, immagine 3 di 3
    • Remove the screws from the front of the bridge.
    • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
  8. Fender Starcaster Bridge Replacement: passo 8, immagine 1 di 1
    • With all six screws removed, lift up on the bridge to remove it from the body.
Conclusione
Altre 2 persone hanno completato questa guida.
Pasco Hernando, Team 5-3, Prince Fall 2014 Membro di Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,402
