Salta al contenuto principale
Fender Frontman 15r Fuse Replacement
Cosa ti serve
  1. Fender Frontman 15r Fuse Replacement, Fuse: passo 1, immagine 1 di 3 Fender Frontman 15r Fuse Replacement, Fuse: passo 1, immagine 2 di 3 Fender Frontman 15r Fuse Replacement, Fuse: passo 1, immagine 3 di 3
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
  2. Fender Frontman 15r Fuse Replacement: passo 2, immagine 1 di 2 Fender Frontman 15r Fuse Replacement: passo 2, immagine 2 di 2
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
Conclusione
Cal Poly, Team 24-30, Regan Fall 2012 Membro di Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 48
Tutti i Tempi: 13,502
