Salta al contenuto principale
Fender 65 Twin Reverb Speaker Replacement
Cosa ti serve
  1. Fender 65 Twin Reverb Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Fender 65 Twin Reverb Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier.
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Speaker Replacement: passo 2, immagine 1 di 2 Fender 65 Twin Reverb Speaker Replacement: passo 2, immagine 2 di 2
    • Make sure to unplug the power cord and have the amplifier turned off.
    • Unplug the audio cable running from the port labeled "INT. Speakers" to the audio speakers.
    • You should know have clean access to the speakers.
  3. Fender 65 Twin Reverb Speaker Replacement: passo 3, immagine 1 di 3 Fender 65 Twin Reverb Speaker Replacement: passo 3, immagine 2 di 3 Fender 65 Twin Reverb Speaker Replacement: passo 3, immagine 3 di 3
    • Locate the wire leads on the speaker that you are replacing. Notice that there are three wires and four connections.
    • Note where each wire goes. (White is positive and black is negative.
    • Remove the wires from the speaker leads.
  4. Fender 65 Twin Reverb Speaker Replacement: passo 4, immagine 1 di 3 Fender 65 Twin Reverb Speaker Replacement: passo 4, immagine 2 di 3 Fender 65 Twin Reverb Speaker Replacement: passo 4, immagine 3 di 3
    • Remove all the screws on the perimeter of the speaker. Use locking pliers to remove the nuts. There are eight bolts holding the speaker in place.
    • Pull the old speaker off of the board and insert the new speaker the same way you removed the old one.
    • When tightening the nuts back down on the bolts, be sure to tighten them by alternating, working in diagonals. (i.e. once you tighten one down go diagonal from it and work on the next one.
    • Repeat with the other speaker if necessary.
Conclusione
Altre 4 persone hanno completato questa guida.
Documenti Allegati
Ryan Brown
Membro da: 02/20/14
210 Reputazione
1 Guida realizzata
Cal Poly, Team 9-27, Maness Winter 2014 Membro di Cal Poly, Team 9-27, Maness Winter 2014
CPSU-MANESS-W14S9G27
5 Membri
7 Guide realizzate
2 Commenti
Thanks for the tutorial.
csharpconsultant - Replica
Am I missing a step here? You have the chassis in the way to access to speakers. Do u remove the chassis or do you remove the tolex with the speakers attached to it? Thanks
Albert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 6,352
