Salta al contenuto principale
Fender '65 Tube Amp Speaker Replacement
Cosa ti serve
  1. Fender '65 Tube Amp Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Lay the amplifier face-down.
  2. Fender '65 Tube Amp Speaker Replacement: passo 2, immagine 1 di 1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender '65 Tube Amp Speaker Replacement: passo 3, immagine 1 di 2 Fender '65 Tube Amp Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender '65 Tube Amp Speaker Replacement: passo 4, immagine 1 di 3 Fender '65 Tube Amp Speaker Replacement: passo 4, immagine 2 di 3 Fender '65 Tube Amp Speaker Replacement: passo 4, immagine 3 di 3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender '65 Tube Amp Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender '65 Tube Amp Speaker Replacement: passo 6, immagine 1 di 3 Fender '65 Tube Amp Speaker Replacement: passo 6, immagine 2 di 3 Fender '65 Tube Amp Speaker Replacement: passo 6, immagine 3 di 3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender '65 Tube Amp Speaker Replacement: passo 7, immagine 1 di 3 Fender '65 Tube Amp Speaker Replacement: passo 7, immagine 2 di 3 Fender '65 Tube Amp Speaker Replacement: passo 7, immagine 3 di 3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 57
