Salta al contenuto principale
Faulty Plug Prongs Repair
Cosa ti serve
  1. Faulty Plug Prongs Repair, Faulty Plug Prongs Repair: passo 1, immagine 1 di 1
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Faulty Plug Prongs Repair: passo 2, immagine 1 di 1
    • If the prongs are bent out of shape, take the pliers and slowly apply pressure so that the prongs bend back to their regular shape.
    • It doesn't have to be perfect. It just has to fit into the outlet.
  3. Faulty Plug Prongs Repair: passo 3, immagine 1 di 1
    • Plug the power cord into the outlet and make sure that it's connected to the device.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
7 Guide realizzate
Un commento
What if the casing is broken and needs to be replaced?
Bertha Torres - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 207
Tutti i Tempi: 16,636
