Salta al contenuto principale
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Fatshark FPV Headset 1000mah Battery, usa il nostro manuale di assistenza.
  1. Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: passo 1, immagine 1 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: passo 1, immagine 2 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: passo 1, immagine 3 di 3
    • Cut the adhesive label down the seam of the battery case.
    • Do not cut down into the case as puncturing the battery will cause a fire.
    • Separate the two plastic case shells to expose the battery inside.
  2. Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: passo 2, immagine 1 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: passo 2, immagine 2 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: passo 2, immagine 3 di 3
    • Remove the tape holding the battery cells together.
    • Do not stress the tabs on the battery cells or short any of the metallic contacts on the internal circuit board.
  3. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: passo 3, immagine 1 di 2 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: passo 3, immagine 2 di 2
    • Desolder the two battery tabs with black and white wires connected to them.
    • Do not short the battery cells or the metallic contacts on the internal PCB.
  4. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: passo 4, immagine 1 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: passo 4, immagine 2 di 3 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: passo 4, immagine 3 di 3
    • First, desolder the battery tabs from the PCB.
    • Second, desolder the main barrel connector wires and balance plug wires from the internal PCB.
  5. Fatshark FPV Headset 1000mah Battery Teardown, That's it!: passo 5, immagine 1 di 3 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: passo 5, immagine 2 di 3 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: passo 5, immagine 3 di 3
    • Extra photos of components.
David Hoyt
Membro da: 04/09/10
4.053 Reputazione
39 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
59 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,545
