Salta al contenuto principale
Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement
Cosa ti serve
  1. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement, Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 1, immagine 1 di 2 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement, Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 1, immagine 2 di 2
    • Be sure to disconnect the dryer from its power source prior to starting the replacement process.
    • Open the Dryer Door.
  2. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 2, immagine 1 di 2 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 2, immagine 2 di 2
    • Take the pliers and clamp onto the strike.
    • Push it from one side and then lift it out on the other side.
  3. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 3, immagine 1 di 1
    • Compare the old strike to the new ones that come in the kit to see which one will go into our dryer.
    • Make sure the new strike has all of the same fittings as the old strike.
  4. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 4, immagine 1 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 4, immagine 2 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 4, immagine 3 di 3
    • Take the new strike and set it into position.
    • Using a bottle nose pliers, push on one side of the strike until it's in place.
    • Using your hand, push the strike into place.
  5. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 5, immagine 1 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 5, immagine 2 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 5, immagine 3 di 3
    • Next, we'll replace the catch.
    • Remove the screws that are holding the inside of the door to the outside panel.
    • Once both screws are removed, you now have access to the back of the door catch.
  6. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 6, immagine 1 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 6, immagine 2 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 6, immagine 3 di 3
    • Take the pliers and push out the top of the door catch.
    • Now, take the pliers and push out the bottom of the catch.
    • Take the pliers and squeeze the metal clip, then push the catch all the way through.
  7. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 7, immagine 1 di 1
    • Take the new catch and place it into the original opening where we removed the old catch.
  8. Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 8, immagine 1 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 8, immagine 2 di 3 Fast Fix Whirlpool Cabrio WGD5500XW1 Door Latch Replacement: passo 8, immagine 3 di 3
    • Replace the screws that were removed and put the door back together.
    • After confirming the door shuts properly, reconnect the dryer to its power source and test out the dryer to ensure the door remains closed while in operation.
    • If the door remains closed during the test run, the repair is done.
Conclusione
BizzzyBeee
Membro da: 06/27/23
184 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 40
Tutti i Tempi: 515
