Salta al contenuto principale
Fast Fix Shower Curtain Permanent Rod Replacement
Cosa ti serve
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: passo 1, immagine 1 di 1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: passo 2, immagine 1 di 2 Fast Fix Shower Curtain Permanent Rod Replacement: passo 2, immagine 2 di 2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: passo 3, immagine 1 di 1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: passo 4, immagine 1 di 1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: passo 5, immagine 1 di 1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: passo 6, immagine 1 di 2 Fast Fix Shower Curtain Permanent Rod Replacement: passo 6, immagine 2 di 2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
Conclusione
To reassemble your device, follow these instructions in reverse order
Abdul-Jabbar Mohamed
Membro da: 09/15/20
134 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 421
