Introduzione
This guide can be used to remove and replace a screen on a Dell Insprion 15-3521. The tools needed are a small Phillips screwdriver, and a small flat screwdriver or like prying device.
Cosa ti serve
Use a small screwdriver to press in the keyboard latches.
Remove the keyboard.
Unplug the keyboard cable at the ZIF connection.
The Zif Connector has to be opened before taking the cable out
this applies to any Zif connector
Altre 3 persone hanno completato questa guida.
Un commento
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
