Salta al contenuto principale
Kenmore Model 110 Clutch Replacement
Cosa ti serve
  1. Kenmore Model 110 Clutch Replacement, Transmission Clutch: passo 1, immagine 1 di 2 Kenmore Model 110 Clutch Replacement, Transmission Clutch: passo 1, immagine 2 di 2
    • Unplug the washing machine.
    • Turn both the hot and cold water supply lines off.
  2. Kenmore Model 110 Clutch Replacement: passo 2, immagine 1 di 1
    • Disconnect the supply hoses using channel lock pliers. Use the towel to catch any water that may spill out.
  3. Kenmore Model 110 Clutch Replacement: passo 3, immagine 1 di 1
    • Use the channel lock pliers to remove tension on the hose spring clamp and pull the drain line from the washer.
    • Water will come out when hose is disconnected.
  4. Kenmore Model 110 Clutch Replacement: passo 4, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 4, immagine 2 di 2
    • Pinch the plastic tabs with the needle nose pliers and push through the metal back panel.
  5. Kenmore Model 110 Clutch Replacement: passo 5, immagine 1 di 1
    • Pull up the control panel located on top of the washer machine.
  6. Kenmore Model 110 Clutch Replacement: passo 6, immagine 1 di 1
    • Lift the plastic tab on the timer wiring harness connector and pull from the timer.
  7. Kenmore Model 110 Clutch Replacement: passo 7, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 7, immagine 2 di 2
    • Disconnect the hose and wiring harness from water level control.
  8. Kenmore Model 110 Clutch Replacement: passo 8, immagine 1 di 3 Kenmore Model 110 Clutch Replacement: passo 8, immagine 2 di 3 Kenmore Model 110 Clutch Replacement: passo 8, immagine 3 di 3
    • Push tab and remove the connector that is next to the water level control on the inside of the control panel.
    • Pull the connector from the door safety switch located on the main body of the washing machine top.
    • Disconnect the green wire ground point inside the control panel with the ratchet and a 1/4 inch socket.
  9. Kenmore Model 110 Clutch Replacement: passo 9, immagine 1 di 1
    • Use the flat head screwdriver to pry out clips on left and right side on top of the machine where the control panel was.
  10. Kenmore Model 110 Clutch Replacement: passo 10, immagine 1 di 3 Kenmore Model 110 Clutch Replacement: passo 10, immagine 2 di 3 Kenmore Model 110 Clutch Replacement: passo 10, immagine 3 di 3
    • Pull the hood gently from the front to separate from the base, leaving the tub, motor, and transmission exposed.
    • Carefully tilt the washer and set it on the back panel
  11. Kenmore Model 110 Clutch Replacement: passo 11, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 11, immagine 2 di 2
    • Remove the pump retaining clips.
    • Leave the pump hoses attached and move the pump aside.
  12. Kenmore Model 110 Clutch Replacement: passo 12, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 12, immagine 2 di 2
    • Lift the tab and remove the motor wiring harness connector.
    • Remove the plastic clip from the transmission housing.
  13. Kenmore Model 110 Clutch Replacement: passo 13, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 13, immagine 2 di 2
    • Remove the motor retaining clip screws with the ratchet and a 1/4 inch socket.
    • Use the flat head screw driver to pry retaining clips off of motor.
  14. Kenmore Model 110 Clutch Replacement: passo 14, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 14, immagine 2 di 2
    • Separate the motor from the transmission.
    • Be sure to check the rubber motor coupling while it is apart. The motor and the transmission will have a plastic piece with three prongs that fit into the rubber coupling. Check to make sure plastic prongs have not broken and the rubber coupling is not cracked.
    • If the motor coupling is cracked or broken it will need to be replaced.
  15. Kenmore Model 110 Clutch Replacement: passo 15, immagine 1 di 3 Kenmore Model 110 Clutch Replacement: passo 15, immagine 2 di 3 Kenmore Model 110 Clutch Replacement: passo 15, immagine 3 di 3
    • Inside the wash tank, use the flat head screw driver to pop cap off of the agitator.
    • Remove the transmission shaft nut with the ratchet and a 7/16 inch socket.
    • Remove the agitator by pulling it from the transmission shaft.
  16. Kenmore Model 110 Clutch Replacement: passo 16, immagine 1 di 2 Kenmore Model 110 Clutch Replacement: passo 16, immagine 2 di 2
    • On the bottom of the machine, remove the 3 bolts that hold the transmission in place with the ratchet and a 3/8 inch socket.
    • Gently pull the transmission out of the washer.
  17. Kenmore Model 110 Clutch Replacement: passo 17, immagine 1 di 3 Kenmore Model 110 Clutch Replacement: passo 17, immagine 2 di 3 Kenmore Model 110 Clutch Replacement: passo 17, immagine 3 di 3
    • Remove the metal washer from the transmission shaft.
    • Pry the retaining clip from the transmission shaft with the flat head screw driver.
    • Pry the spring clip from the clutch with the flat head screw driver.
  18. Kenmore Model 110 Clutch Replacement: passo 18, immagine 1 di 1
    • Remove the clutch.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Nice tutorial! Thank you!
jdickes427 - Replica
My Kenmore washer is as same as this one, but now the agitator works, but it does not spin. So far I reached step 14, did not find anything wrong, which parts could be the problem? Clutch? Thanks
Harry Song - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 267
Tutti i Tempi: 13,474
