Introduzione
In this guide, we will explain how to replace a valve stem, such that people of all mechanical backgrounds can attempt this repair. This guide assumes you have removed your wheel from the vehicle. For instructions on removing the wheel, refer to this guide.
Cosa ti serve
The tire must be re-inflated. Simply use your air compressor to inflate the tire. We recommend re-inflating to 32 p.s.i. to check for leaks.
Insert the pry bar in between the rim and the tire. Push the pry bar as far down as possible. This will require a large amount of force.
The bead is broken when the tire is visibly separated from the rim. Use the pry bar to hold the tire down by leveraging it against the small lip inside the rim.
If all goes well, your tire should be fully resealed and good as new.
Altre 2 persone hanno completato questa guida.
