Salta al contenuto principale
Fast Fix Box Cutter Blade Replacement
Cosa ti serve
  1. Fast Fix Box Cutter Blade Replacement, Blade: passo 1, immagine 1 di 3 Fast Fix Box Cutter Blade Replacement, Blade: passo 1, immagine 2 di 3 Fast Fix Box Cutter Blade Replacement, Blade: passo 1, immagine 3 di 3
    • The case screw can easily be removed by using a Stanley #2 screwdriver or any other #2 screwdriver.
  2. Fast Fix Box Cutter Blade Replacement: passo 2, immagine 1 di 1
    • Separate casing by simply pulling apart both halves.
  3. Fast Fix Box Cutter Blade Replacement: passo 3, immagine 1 di 2 Fast Fix Box Cutter Blade Replacement: passo 3, immagine 2 di 2
    • Carefully, using the pull tab, take out the blade holder and set it on the table.
    • Remove the blade by carefully sliding it out of the holder.
    • Be very careful when dealing with the blade as it is sharp.
  4. Fast Fix Box Cutter Blade Replacement: passo 4, immagine 1 di 2 Fast Fix Box Cutter Blade Replacement: passo 4, immagine 2 di 2
    • Replace the old blade with the new blade by carefully sliding it into the blade holder.
    • Place the blade holder back into the casing using the pull tab to hold it.
  5. Fast Fix Box Cutter Blade Replacement: passo 5, immagine 1 di 2 Fast Fix Box Cutter Blade Replacement: passo 5, immagine 2 di 2
    • Add grease to the sliding mechanism
    • Use either a paper towel or a cloth to spread the grease around the sliding mechanism.
  6. Fast Fix Box Cutter Blade Replacement: passo 6, immagine 1 di 2 Fast Fix Box Cutter Blade Replacement: passo 6, immagine 2 di 2
    • Take the other half without the blade and put it back together with the other half with the blade.
    • Snap the two parts together.
    • Place the screw back in to hole while holding the casing together.
  7. Fast Fix Box Cutter Blade Replacement: passo 7, immagine 1 di 2 Fast Fix Box Cutter Blade Replacement: passo 7, immagine 2 di 2
    • Use Stanley #2, or any other #2, screwdriver to screw the casing back together.
    • To ensure proper placement of the blade, activate the mechanism that slides the blade out.
    • Once it comes out, like in second picture, you are done.
Conclusione
Peace Adeyemo
Membro da: 02/22/18
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 8,871
