Salta al contenuto principale
Farberware FSTO100 Power Supply Replacement
Cosa ti serve
  1. Farberware FSTO100 Power Supply Replacement, Power Supply: passo 1, immagine 1 di 1
    • Make sure the toaster is unplugged.
    • First, to remove the plastic bracket, turn toaster oven on its side.
  2. Farberware FSTO100 Power Supply Replacement: passo 2, immagine 1 di 1
    • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  3. Farberware FSTO100 Power Supply Replacement: passo 3, immagine 1 di 1
    • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  4. Farberware FSTO100 Power Supply Replacement: passo 4, immagine 1 di 1
    • If the wire gets pulled out of the transformer, reinsert it.
    • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Conclusione
Tony Wang
Membro da: 10/05/12
103 Reputazione
5 Guide realizzate
Cal Poly, Team 6-35, Regan Fall 2012 Membro di Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,436
