Salta al contenuto principale
Fan Coil Filter Replacement
Cosa ti serve
  1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: passo 1, immagine 1 di 1
    • Clean the fan coil grilles using a paper towel and water.
    • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
  2. Fan Coil Filter Replacement: passo 2, immagine 1 di 1
    • Close off each adjustable damper.
    • This will ensure that the register grille does not get in the way later on during the filter removal.
  3. Fan Coil Filter Replacement: passo 3, immagine 1 di 2 Fan Coil Filter Replacement: passo 3, immagine 2 di 2
    • Remove the screws from fan coil using a Phillips #1 screwdriver.
    • Open up the fan coil.
  4. Fan Coil Filter Replacement: passo 4, immagine 1 di 1
    • Use your hands to remove the filter from the fan coil.
  5. Fan Coil Filter Replacement: passo 5, immagine 1 di 2 Fan Coil Filter Replacement: passo 5, immagine 2 di 2
    • Replace the fan coil filter.
    • Make sure to close the fan coil door after the filter replacement is completed.
  6. Fan Coil Filter Replacement: passo 6, immagine 1 di 2 Fan Coil Filter Replacement: passo 6, immagine 2 di 2
    • Screw in closed the fan coil door.
    • Open up each of the adjustable dampers for better air flow.
Conclusione
Following these steps, you will be able to replace the filter in your fan coil system.
Abukar Ahmed
Membro da: 09/20/20
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,032
