Salta al contenuto principale
Fairphone SIM Card Replacement
  1. Fairphone SIM Card Replacement, Back Cover: passo 1, immagine 1 di 3 Fairphone SIM Card Replacement, Back Cover: passo 1, immagine 2 di 3 Fairphone SIM Card Replacement, Back Cover: passo 1, immagine 3 di 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone SIM Card Replacement: passo 2, immagine 1 di 3 Fairphone SIM Card Replacement: passo 2, immagine 2 di 3 Fairphone SIM Card Replacement: passo 2, immagine 3 di 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone SIM Card Replacement, Battery: passo 3, immagine 1 di 3 Fairphone SIM Card Replacement, Battery: passo 3, immagine 2 di 3 Fairphone SIM Card Replacement, Battery: passo 3, immagine 3 di 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone SIM Card Replacement: passo 4, immagine 1 di 1
    • Remove the battery from your Fairphone.
  5. Fairphone SIM Card Replacement, SIM and MicroSD Card: passo 5, immagine 1 di 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: passo 5, immagine 2 di 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: passo 5, immagine 3 di 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone SIM Card Replacement: passo 6, immagine 1 di 2 Fairphone SIM Card Replacement: passo 6, immagine 2 di 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
Conclusione
Sam Goldheart
Membro da: 10/18/12
461.666 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Community
136 Membri
15.157 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 206
Tutti i Tempi: 7,366
