Salta al contenuto principale
Fairphone 3 Battery Replacement
Cosa ti serve
  1. Fairphone 3 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Fairphone 3 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 3 Battery Replacement: passo 2, immagine 1 di 3 Fairphone 3 Battery Replacement: passo 2, immagine 2 di 3 Fairphone 3 Battery Replacement: passo 2, immagine 3 di 3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Fairphone 3 Battery Replacement, Battery: passo 3, immagine 1 di 2 Fairphone 3 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Fairphone 3 Battery Replacement: passo 4, immagine 1 di 2 Fairphone 3 Battery Replacement: passo 4, immagine 2 di 2
    • Lift the battery out of its recess and remove it.
Conclusione
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Altre 11 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
16.731 Guide realizzate
2 Commenti
Vielen Dank!
Einfach und direkt umgesetzt..
carola kamp - Replica
Imagine if all cellphone producers made it this easy :-)
Martin Andre Bae Pedersen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 136
Tutti i Tempi: 8,027
