Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Replace the Display Assembly of your Fairphone 2.
Strumenti
Nessun attrezzo specificato.
Parti
  1. Pick a corner of your slim case and get between the two parts with your thumb's fingernails. Pull up the back part of the slim case to separate the small snap fit connections. Remove the back part of the slim case.
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Get in between the front part of the slim case and the phone's body with your thumb nail. Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display. Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Remove the front part of the slim case.
    • Remove the front part of the slim case.
  4. Push the battery toward the top of the phone. Pull the battery out away from the phone. Pull the battery out away from the phone.
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  5. After taking out the battery you can unlock the display assembly. Flip the two blue switches to the inner position. Slide the display assembly towards the bottom of the phone.
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  6. Take off the display assembly.
    • Take off the display assembly.
Conclusione
Altre 35 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 31/03/2014
82.748 Reputazione
156 Guide realizzate
iFixit Membro di iFixit
Community
135 Membri
15.033 Guide realizzate
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - Replica
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - Replica
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - Replica
FP 1U: Ich habe keine blauen Schalter.....
Birgit - Replica
The Display seem to be stuck completely, any tips on how to move it?
siohdk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 85
Tutti i Tempi: 15,010
