Salta al contenuto principale
Fairphone 1 Display Assembly Replacement
Cosa ti serve
  1. Fairphone 1 Display Assembly Replacement, Back Cover: passo 1, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, Back Cover: passo 1, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, Back Cover: passo 1, immagine 3 di 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Display Assembly Replacement: passo 2, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 2, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 2, immagine 3 di 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Display Assembly Replacement, Battery: passo 3, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, Battery: passo 3, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, Battery: passo 3, immagine 3 di 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: passo 5, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: passo 5, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, SIM and MicroSD Card: passo 5, immagine 3 di 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 Display Assembly Replacement: passo 6, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 6, immagine 2 di 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 Display Assembly Replacement, Midframe Assembly: passo 7, immagine 1 di 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 Display Assembly Replacement: passo 8, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 8, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 8, immagine 3 di 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 Display Assembly Replacement: passo 9, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 9, immagine 2 di 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 Display Assembly Replacement: passo 10, immagine 1 di 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 Display Assembly Replacement: passo 11, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 11, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 11, immagine 3 di 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 Display Assembly Replacement: passo 12, immagine 1 di 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 Display Assembly Replacement, Motherboard Assembly: passo 13, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, Motherboard Assembly: passo 13, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, Motherboard Assembly: passo 13, immagine 3 di 3
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  14. Fairphone 1 Display Assembly Replacement: passo 14, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  15. Fairphone 1 Display Assembly Replacement: passo 15, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 15, immagine 2 di 2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  16. Fairphone 1 Display Assembly Replacement: passo 16, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 16, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 16, immagine 3 di 3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  17. Fairphone 1 Display Assembly Replacement: passo 17, immagine 1 di 1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  18. Fairphone 1 Display Assembly Replacement: passo 18, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 18, immagine 2 di 2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  19. Fairphone 1 Display Assembly Replacement: passo 19, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 19, immagine 2 di 2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  20. Fairphone 1 Display Assembly Replacement: passo 20, immagine 1 di 1
    • Remove the motherboard from the display assembly.
  21. Fairphone 1 Display Assembly Replacement, Wi-Fi Antenna Daughterboard: passo 21, immagine 1 di 1
    • Be careful to pry on the connector, not the socket.
  22. Fairphone 1 Display Assembly Replacement: passo 22, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 22, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 22, immagine 3 di 3
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
  23. Fairphone 1 Display Assembly Replacement: passo 23, immagine 1 di 1
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Two 2.5 mm Phillips #000 screws
    • One 1.6 mm Phillips #000 screw
  24. Fairphone 1 Display Assembly Replacement: passo 24, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 24, immagine 2 di 2
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
  25. Fairphone 1 Display Assembly Replacement, Earpiece Speaker: passo 25, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, Earpiece Speaker: passo 25, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, Earpiece Speaker: passo 25, immagine 3 di 3
    • The earpiece speaker is held to the back of the display assembly with some mild adhesive.
    • Use the tip of a spudger to gently pry the speaker up from the display assembly.
    • Remove the speaker.
  26. Fairphone 1 Display Assembly Replacement, Display Assembly: passo 26, immagine 1 di 3 Fairphone 1 Display Assembly Replacement, Display Assembly: passo 26, immagine 2 di 3 Fairphone 1 Display Assembly Replacement, Display Assembly: passo 26, immagine 3 di 3
    • Remove the antenna interconnect cable from the display assembly.
    • The three sections of the cable with exposed metal fit into the grounding clips on the side of the display assembly.
  27. Fairphone 1 Display Assembly Replacement: passo 27, immagine 1 di 2 Fairphone 1 Display Assembly Replacement: passo 27, immagine 2 di 2
    • Remove the rubber guide from the recess near the front facing camera hole.
    • Be sure not to lose this rubber stopper, transfer it to the new display.
  28. Fairphone 1 Display Assembly Replacement: passo 28, immagine 1 di 3 Fairphone 1 Display Assembly Replacement: passo 28, immagine 2 di 3 Fairphone 1 Display Assembly Replacement: passo 28, immagine 3 di 3
    • Remove the rubber guide to the right of the earpiece speaker recess.
    • Your replacement display will have a piece of yellow tape covering the touch sensor chip. Do not remove this tape; if you do, your phone may not work after reassembly.
Conclusione
Altre 102 persone hanno completato questa guida.
iFixit Membro di iFixit
Community
136 Membri
15.154 Guide realizzate
16 Commenti
So far, so good.
My display is replaced now.
Unfortunately, removing the motherboard easily destroyed the camera, which didn't come up with the motherboard, being glued to display at the back.
So now I gotta get a new camera and do the hole thing again -.-
Atrocio - Replica
step 20:
Watch out not to loose the two rubber things of step 27 and 28 while taking out the motherboard. I foud the small one floor.
Koen Go - Replica
The Camera is not mentioned at all. It's glued to the Display and yet still working, it can't focus anymore. So I might have to get a new one as well.
Juliane Grossmann - Replica
Screen fixed :-) thanks for the guide!
Watch the glued camera on step 19...
Aitor - Replica
Awesome! Did it, and everything still works. Mighty pleased with myself. Thank you, iFixit!!!
Meike Hensmann - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 36,265
