Introduzione
If your FRIGIDARE FFHT1514TW fridge’s light bulb has been used up fully and is no longer letting out any light, use this guide to replace the light bulb of your fridge.
A light bulb lights the interior of a refrigerator and allows for a good view of the contents. A blown bulb makes it harder to detect little things and might lead to further complications.
It is suggested that you buy the correct light bulb before following this guide so you will have everything you need. You might want to buy two sets of light bulbs just in case one set is broken or malfunctioning.
Before attempting this fix, make sure to unplug the fridge from its power outlet.
Cosa ti serve
Lift the shelf right below the light bulb area by lifting the hooks off the side and sliding it out so you have space to do your repair.
