Salta al contenuto principale
FAO Schwarz Apex 1 Front Wheel Springs Replacement
Cosa ti serve
  1. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: passo 1, immagine 1 di 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: passo 1, immagine 2 di 3 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Wheel: passo 1, immagine 3 di 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Wheel Springs Replacement: passo 2, immagine 1 di 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: passo 3, immagine 1 di 2 FAO Schwarz Apex 1 Front Wheel Springs Replacement, Front Wheel Springs: passo 3, immagine 2 di 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Wheel Springs Replacement: passo 4, immagine 1 di 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Wheel Springs Replacement: passo 5, immagine 1 di 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 159
