Introduzione
The Apex 1 features shock-absorbing springs that enable the car to maneuver rough terrain, and help keep the car from flipping. These metal springs could become rusted with age. This guide will help you replace damaged or rusted springs on the front of the car to keep your Apex 1 in optimal condition.
Cosa ti serve
Position device so that the wheels are on a firm surface .
Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
Position device upside down so that the screws on the plastic axle pieces can be removed.
Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
