Salta al contenuto principale
FAO Schwarz Apex 1 Front Axle Replacement
Cosa ti serve
    1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, immagine 1 di 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, immagine 2 di 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: passo 1, immagine 3 di 3
      • Position device so that the wheels are on a firm surface .
      • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
      Chiedi a FixBot
      Aggiungi Commento
    2. FAO Schwarz Apex 1 Front Axle Replacement: passo 2, immagine 1 di 1
      • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
      Chiedi a FixBot
      Aggiungi Commento
    1. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: passo 3, immagine 1 di 2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: passo 3, immagine 2 di 2
      • Position device upside down so that the screws on the plastic axle pieces can be removed.
      • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
      Chiedi a FixBot
      Aggiungi Commento
    2. FAO Schwarz Apex 1 Front Axle Replacement: passo 4, immagine 1 di 1
      • Secure a firm grip on the spring and telescopic piston.
      • Pull telescopic piston holding the spring off the device (this may be difficult).
      Chiedi a FixBot
      Aggiungi Commento
    3. FAO Schwarz Apex 1 Front Axle Replacement: passo 5, immagine 1 di 1
      • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
      Chiedi a FixBot
      Aggiungi Commento
    1. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, immagine 1 di 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, immagine 2 di 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: passo 6, immagine 3 di 3
      • Carefully turn the vehicle over so that the bottom side is facing upward.
      • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
      • Pull the plastic piece that secures the wheel bearing off of the axle.
      Chiedi a FixBot
      Aggiungi Commento
    2. FAO Schwarz Apex 1 Front Axle Replacement: passo 7, immagine 1 di 2 FAO Schwarz Apex 1 Front Axle Replacement: passo 7, immagine 2 di 2
      • Position the axle entirely upright before lifting away from the vehicle.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 22
Tutti i Tempi: 820
