Salta al contenuto principale
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: passo 1, immagine 1 di 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: passo 1, immagine 2 di 2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: passo 2, immagine 1 di 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: passo 2, immagine 2 di 2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 3, immagine 1 di 1
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 4, immagine 1 di 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 4, immagine 2 di 2
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 5, immagine 1 di 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 5, immagine 2 di 2
    • Pull up on the tag and remove the filter.
Conclusione
Anna Snyder
Membro da: 10/02/17
336 Reputazione
3 Guide realizzate
Cal Poly, Team S4-G5, Livingston Fall 2017 Membro di Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 586
