Introduzione
This guide walks you through removing the belt latch assembly in the Eureka SuctionSeal 2.0 Pet vacuum. If the brush roll pedal on your vacuum is not working, you may find this guide useful.
Cosa ti serve
Place the device upright with the brush roller closest to you.
Pull up on the latch at the top of the dust cup.
Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
Locate the gray exhaust filter cover at the top of the vacuum's base.
Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
Lift the cover away from the vacuum.
Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
Remove the two 20mm screws using a JIS 1 screwdriver.
