Salta al contenuto principale
Eureka EasyClean 71C Casing Replacement
Cosa ti serve
  1. Eureka EasyClean 71C Casing Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Casing Replacement: passo 2, immagine 1 di 1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Casing Replacement: passo 3, immagine 1 di 1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Casing Replacement: passo 4, immagine 1 di 2 Eureka EasyClean 71C Casing Replacement: passo 4, immagine 2 di 2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Casing Replacement, Casing: passo 5, immagine 1 di 1
    • Pull the power switch all the way up and remove the dust cup.
  6. Eureka EasyClean 71C Casing Replacement: passo 6, immagine 1 di 2 Eureka EasyClean 71C Casing Replacement: passo 6, immagine 2 di 2
    • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
    • Pull the casing apart.
Conclusione
IUPUI, Team S6-G4, Baechle Fall 2017 Membro di IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 367
