Salta al contenuto principale
Eureka EasyClean 71C Bottom Cover Replacement
Cosa ti serve
  1. Eureka EasyClean 71C Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Bottom Cover Replacement: passo 3, immagine 1 di 1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Bottom Cover Replacement: passo 4, immagine 1 di 2 Eureka EasyClean 71C Bottom Cover Replacement: passo 4, immagine 2 di 2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
Conclusione
IUPUI, Team S6-G4, Baechle Fall 2017 Membro di IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 213
