Salta al contenuto principale
Eureka EasyClean 71C Belt Replacement
Cosa ti serve
  1. Eureka EasyClean 71C Belt Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Belt Replacement: passo 2, immagine 1 di 1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Belt Replacement: passo 3, immagine 1 di 1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Belt Replacement: passo 4, immagine 1 di 2 Eureka EasyClean 71C Belt Replacement: passo 4, immagine 2 di 2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Belt Replacement, Belt: passo 5, immagine 1 di 2 Eureka EasyClean 71C Belt Replacement, Belt: passo 5, immagine 2 di 2
    • Pull the roller, motor, and belt out of the casing.
    • Separate the belt from both the roller and the motor.
Conclusione
IUPUI, Team S6-G4, Baechle Fall 2017 Membro di IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Membri
12 Guide realizzate
Un commento
Hello would you know what belt number this would use? I have looked everywhere. I would appreciate it
vdean4b - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,512
