Salta al contenuto principale
Introduzione
Sometimes, the belt in the vacuum can go bad or even just come loose. In order to properly maintain your vacuum, it’s important to know how to replace the belt. This guide covers the necessary steps for a successful replacement. Make sure your vacuum is off before attempting any replacements.
Ricambi
Nessuna parte specificata.
  1. Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Pry off the Riser Visor using the plastic opening tool.
    • Pry off the Riser Visor using the plastic opening tool.
  3. Remove the screw cap using the metal spudger.
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Unscrew the 14mm PH2 Phillips head screw. Pull the bottom cover off of the rest of the casing.
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Pull the roller, motor, and belt out of the casing. Separate the belt from both the roller and the motor.
    • Pull the roller, motor, and belt out of the casing.
    • Separate the belt from both the roller and the motor.
Conclusione
Tanner Durnil
Membro da: 06/11/2017
631 Reputazione
6 Guide realizzate
IUPUI, Team S6-G4, Baechle Fall 2017 Membro di IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Membri
6 Guide realizzate
Un commento
Hello would you know what belt number this would use? I have looked everywhere. I would appreciate it
vdean4b - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,174
