Salta al contenuto principale
Introduzione
If you determine that your vacuum is no longer picking up debris, this guide will help you to replace the washable filters to increase the suction.
  1. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: passo 1, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: passo 1, immagine 2 di 2
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: passo 2, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: passo 2, immagine 2 di 2
    • Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup.
  3. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: passo 3, immagine 1 di 1
    • Remove the white filter by lifting the gray foam filter handle.
  4. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: passo 4, immagine 1 di 1
    • Push the white mesh, segment below the filter handle downward so it pops out of the grey filter holder. This will remove the filter.
  5. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: passo 5, immagine 1 di 1
    • If filter is unable to be washed, place a new filter in gray holder.
Conclusione
Celina Burchett
Membro da: 13/10/2014
1.122 Reputazione
8 Guide realizzate
Clemson, Team 2-2, Benson Fall 2014 Membro di Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Membri
16 Guide realizzate
Un commento
Can you wash the white filter within the grey holder?
Lloyd C - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 379
Tutti i Tempi: 7,419
