Salta al contenuto principale
Introduzione
If you determine that your vacuum is no longer picking up debris, this guide will help you to replace the wash screen to increase the suction.
  1. Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement, Wash Screen: passo 1, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement, Wash Screen: passo 1, immagine 2 di 2
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement: passo 2, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement: passo 2, immagine 2 di 2
    • Twist the large, black portion of the cyclone/dust cup to the right to unlock the black cyclone from the clear dust cup.
  3. Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement: passo 3, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement: passo 3, immagine 2 di 2
    • Twist the clear collar to release the wash screen and small circular collar.
  4. Eureka AirSpeed Bagless Zuum Vacuum Wash Screen Replacement: passo 4, immagine 1 di 1
    • If screen is beyond washing clean or is cracked, connect new screen to cyclone and collar.
Conclusione
Celina Burchett
Membro da: 13/10/2014
1.122 Reputazione
8 Guide realizzate
Clemson, Team 2-2, Benson Fall 2014 Membro di Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Membri
16 Guide realizzate
3 Commenti
Where do i purchase this replacement part? I can't find it anywhere.
jane pultz - Replica
reattaching the collar to the wash screen is NOT EASY! I am not able to do it. What is the trick here??
ramsgusom - Replica
Nvm. Just had to use my brain. there is a small groove in the plastic cylinder of the vacuum cleaner - the screen has to go below this - so that the collar can slide into the groove.
ramsgusom -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,732
