Salta al contenuto principale
Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement
Cosa ti serve
  1. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: passo 1, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: passo 1, immagine 2 di 2
    • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  2. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: passo 2, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: passo 2, immagine 2 di 2
    • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  3. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Accessory Holder: passo 3, immagine 1 di 1
    • Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
  4. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: passo 4, immagine 1 di 1
    • Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
Conclusione
Clemson, Team 2-2, Benson Fall 2014 Membro di Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 604
