Salta al contenuto principale
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
Cosa ti serve
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: passo 1, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: passo 1, immagine 2 di 2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 3, immagine 1 di 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 3, immagine 2 di 2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 4, immagine 1 di 1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 5, immagine 1 di 1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 6, immagine 1 di 1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
Conclusione
Altre 6 persone hanno completato questa guida.
Clemson, Team 2-2, Benson Fall 2014 Membro di Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Membri
18 Guide realizzate
Un commento
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 12,009
