Salta al contenuto principale
Introduzione
Replace the small wheel or 'roller' on the bottom of the Eureka.
Parti
Nessuna parte specificata.
  1. Press the black separator switch and lightly pull the bottom half away from the top. Press the black separator switch and lightly pull the bottom half away from the top.
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Remove the vacuum head from the lower half of the body. Remove the vacuum head from the lower half of the body.
    • Remove the vacuum head from the lower half of the body.
  3. Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver. Separate the top and bottom of the vacuum head. Set the top aside. Separate the top and bottom of the vacuum head. Set the top aside.
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Turn the vacuum head's bottom over so that the inside of the head is facing up. Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Press the new bar and roller into place.
    • Press the new bar and roller into place.
    • Replace the screws.
Linea Traguardo
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 129
