Salta al contenuto principale
Eufy RoboVac 11S Filters Replacement
Cosa ti serve
  1. Eufy RoboVac 11S Filters Replacement, Filters: passo 1, immagine 1 di 2 Eufy RoboVac 11S Filters Replacement, Filters: passo 1, immagine 2 di 2
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: passo 2, immagine 1 di 2 Eufy RoboVac 11S Filters Replacement: passo 2, immagine 2 di 2
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: passo 3, immagine 1 di 3 Eufy RoboVac 11S Filters Replacement: passo 3, immagine 2 di 3 Eufy RoboVac 11S Filters Replacement: passo 3, immagine 3 di 3
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: passo 4, immagine 1 di 3 Eufy RoboVac 11S Filters Replacement: passo 4, immagine 2 di 3 Eufy RoboVac 11S Filters Replacement: passo 4, immagine 3 di 3
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: passo 5, immagine 1 di 1
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: passo 6, immagine 1 di 2 Eufy RoboVac 11S Filters Replacement: passo 6, immagine 2 di 2
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: passo 7, immagine 1 di 2 Eufy RoboVac 11S Filters Replacement: passo 7, immagine 2 di 2
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
Conclusione
Altre 2 persone hanno completato questa guida.
felix
Membro da: 05/13/20
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 73
Tutti i Tempi: 4,978
