Salta al contenuto principale
Eufy RoboVac 11S Drive Wheels Replacement
Cosa ti serve
  1. Eufy RoboVac 11S Drive Wheels Replacement, Drive Wheels: passo 1, immagine 1 di 1
    • Turn off the RoboVac's power and flip it over onto a soft surface.
  2. Eufy RoboVac 11S Drive Wheels Replacement: passo 2, immagine 1 di 1
    • Remove the side brushes by pulling them off.
  3. Eufy RoboVac 11S Drive Wheels Replacement: passo 3, immagine 1 di 1
    • Use the Phillips screwdriver to remove the four 5 mm screws in front of the wheel being replaced.
  4. Eufy RoboVac 11S Drive Wheels Replacement: passo 4, immagine 1 di 1
    • Lift the wheel slightly and disconnect the spring and cable connected to it.
    • Wiggle the cable gently to detach it.
  5. Eufy RoboVac 11S Drive Wheels Replacement: passo 5, immagine 1 di 1
    • Fully remove the old wheel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 200
