Salta al contenuto principale
Eufy Clean RoboVac G32 Pro Battery Replacement
Cosa ti serve
  1. Eufy Clean RoboVac G32 Pro Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your device is turned off.
    • Flip the device upside down on a flat surface.
  2. Eufy Clean RoboVac G32 Pro Battery Replacement: passo 2, immagine 1 di 1
    • Remove two 10 mm screws using a Phillips #1 screwdriver.
  3. Eufy Clean RoboVac G32 Pro Battery Replacement: passo 3, immagine 1 di 1
    • Lift the cover of the battery.
  4. Eufy Clean RoboVac G32 Pro Battery Replacement: passo 4, immagine 1 di 1
    • Lift up the battery using the white straps on the side.
  5. Eufy Clean RoboVac G32 Pro Battery Replacement: passo 5, immagine 1 di 2 Eufy Clean RoboVac G32 Pro Battery Replacement: passo 5, immagine 2 di 2
    • While holding the battery, pinch the clips on the side of the white connector.
    • Using a spudger, push the part of the connector inside of the Robovac away from the white connector on the battery.
    • Pinch the clips hard; they may be a little stiff.
    • Remove the battery from the device.
Conclusione
Marist, Team 1-4, Chaterdon Spring 2023 Membro di Marist, Team 1-4, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 808
