Introduzione
If you aren't able to adjust the radio's volume, the volume dial may not be working. In just a few minutes, though, you can get it replaced!
It's important not to mix this up with the tuning dial, as they are unique components and will not be interchangable.
Strumenti
Ricambi
Nessuna parte specificata.
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
