Introduzione
LEDs last for a really long time, but alas, not forever. You may find the need to replace the LED module in the future, but it's just a matter of opening the case and pulling it out!
Strumenti
Ricambi
Nessuna parte specificata.
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Quasi finito!
To reassemble your device, follow these instructions in the reverse order.
Conclusione
