Introduzione
The I/O board houses the 3.5mm plugs for AUX input and a headphone output, the USB charging plug for a smartphone, and the DC input. In the case that any of these are damaged, the entire board may need to be replaced.
Strumenti
Ricambi
Nessuna parte specificata.
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Desolder the red and white wires, where the backup batteries connect to the I/O board.
To reassemble your device, follow these instructions in the reverse order.
Un commento
You say “No parts required,” list a soldering station that you never use, and only tell us how to get the board out.
My USB Connector got ripped off the ckt board, I was hoping to find a source (parts) for the replacement board…
“In the case that any of these are damaged, the entire board may need to be replaced.”
