Introduzione
If your AM Radio is not receiving signal, then you may be in a deadzone or it might be broken. If it is damaged, you will need to follow this guide to replace it.
Cosa ti serve
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Unplug the socket connection from the motherboard as shown in the image.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
On the back of the motherboard, remove the two Philips #0 screws.
To reassemble your device, follow these instructions in the reverse order.
