Salta al contenuto principale
Etekcity Lasergrip 1080 Screen Replacement
Cosa ti serve
  1. Etekcity Lasergrip 1080 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Screen Replacement: passo 2, immagine 1 di 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Screen Replacement: passo 3, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Screen Replacement, Buttons: passo 4, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement, Buttons: passo 4, immagine 2 di 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Screen Replacement: passo 5, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Screen Replacement: passo 7, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement: passo 7, immagine 2 di 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Screen Replacement: passo 8, immagine 1 di 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Screen Replacement, Etekcity Lasergrip 1080 Trigger Replacement: passo 9, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement, Etekcity Lasergrip 1080 Trigger Replacement: passo 9, immagine 2 di 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Screen Replacement, Screen: passo 10, immagine 1 di 1
    • Carefully pull the motherboard out of its slot in the body of the device.
  11. Etekcity Lasergrip 1080 Screen Replacement: passo 11, immagine 1 di 2 Etekcity Lasergrip 1080 Screen Replacement: passo 11, immagine 2 di 2
    • Unscrew the two 3.4 mm screws on the motherboard.
  12. Etekcity Lasergrip 1080 Screen Replacement: passo 12, immagine 1 di 1
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
Conclusione
Carlos Pineda
Membro da: 08/27/15
195 Reputazione
1 Guida realizzata
USF Tampa, Team 5-1, Blackwell Fall 2015 Membro di USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 952
