Salta al contenuto principale
Etekcity Lasergrip 1080 Button Replacement
Cosa ti serve
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: passo 1, immagine 1 di 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: passo 2, immagine 1 di 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: passo 3, immagine 1 di 2 Etekcity Lasergrip 1080 Button Replacement: passo 3, immagine 2 di 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: passo 4, immagine 1 di 2 Etekcity Lasergrip 1080 Button Replacement, Buttons: passo 4, immagine 2 di 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: passo 5, immagine 1 di 2 Etekcity Lasergrip 1080 Button Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: passo 6, immagine 1 di 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: passo 7, immagine 1 di 2 Etekcity Lasergrip 1080 Button Replacement: passo 7, immagine 2 di 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: passo 8, immagine 1 di 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
Conclusione
USF Tampa, Team 5-1, Blackwell Fall 2015 Membro di USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 451
