Salta al contenuto principale
Escort Passport Max2 Lens Replacement
Cosa ti serve
  1. Escort Passport Max2 Lens Replacement, Exterior Case: passo 1, immagine 1 di 2 Escort Passport Max2 Lens Replacement, Exterior Case: passo 1, immagine 2 di 2
    • Inser the flat end of a spudger into one of the two notches and pry off the case.
  2. Escort Passport Max2 Lens Replacement: passo 2, immagine 1 di 2 Escort Passport Max2 Lens Replacement: passo 2, immagine 2 di 2
    • Slide the spudger around the perimeter of the radar housing until the case separates.
  3. Escort Passport Max2 Lens Replacement: passo 3, immagine 1 di 2 Escort Passport Max2 Lens Replacement: passo 3, immagine 2 di 2
    • Repeat these steps to remove the other side.
  4. Escort Passport Max2 Lens Replacement, Lens: passo 4, immagine 1 di 2 Escort Passport Max2 Lens Replacement, Lens: passo 4, immagine 2 di 2
    • Remove the four 9mm Phillips #1 screws from the bottom of the radar.
    • Remove the bottom case.
  5. Escort Passport Max2 Lens Replacement: passo 5, immagine 1 di 1
    • Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
    • The silver frame can easily pop off of the device now that the bottom metal case has been removed. Don't worry if it comes off all the way. It can easily be put back in it's place.
Conclusione
UW Tacoma, Team S1-G1, Liner Spring 2018 Membro di UW Tacoma, Team S1-G1, Liner Spring 2018
UWT-LINER-S18S1G1
5 Membri
4 Guide realizzate
Un commento
Where can I buy a replacement lens?
Kit - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 348
