Salta al contenuto principale
Ersa i-CON 1 Display Replacement
Cosa ti serve
  1. Ersa i-CON 1 Display Replacement, Remove the control knob: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Spudger
    $3.99
    • Pull off the control knob using a nylon spudger.
    • Alternatively, a flat head screwdriver can be used, but be cautious of potential scratches on the metal faceplate.
  2. Ersa i-CON 1 Display Replacement, Remove bottom screws: passo 2, immagine 1 di 1
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Flip the station over and remove the four T20 screws.
    • Flip the station back onto its base and lift the top cover up and off the station.
  3. Ersa i-CON 1 Display Replacement, Remove display nuts: passo 3, immagine 1 di 1
    • Use pliers or a wrench to unscrew the four plastic nuts holding the display in place.
  4. Ersa i-CON 1 Display Replacement, Disconnect the display cable: passo 4, immagine 1 di 1
    Spudger
    $3.99
    • Carefully flip the display upwards.
    • Loosen the display connector by pushing up the small brown bars on both sides of the connector with a spudger or similar tool.
    • Pull the ribbon cable from the connector.
Conclusione
Altre 3 persone hanno completato questa guida.
Sebastian
Membro da: 08/19/18
31.187 Reputazione
71 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 562
