Salta al contenuto principale
Equity Alarm Clock 13014 Clock Bell Hammer Replacement
Cosa ti serve
  1. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, immagine 1 di 3 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, immagine 2 di 3 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, immagine 3 di 3
    • Using a Phillip's Screwdriver, remove the three screws on the back cover of the clock.
  2. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock (2): passo 2, immagine 1 di 1
    • Using your hands, remove the back cover of the clock by grasping it and pulling it upwards.
  3. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: passo 3, immagine 1 di 2 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: passo 3, immagine 2 di 2
    • Using a Phillips Screwdriver, remove the Cellinoid Cover from inner clock apparatus.
  4. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: passo 4, immagine 1 di 2 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: passo 4, immagine 2 di 2
    • Using your fingers, remove the bell hammer from the inner apparatus of clock.
  5. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, You are Finished: passo 5, immagine 1 di 1
    • Remove the clock's bell hammers and you are finished. Be sure to replace the old bell hammers with new ones.
    • Starting from Step 5, repeat each previous step to reassemble the clock.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,210
