Cosa ti serve
Use a spudger to open and detach the wiring box from the clock. Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock. Be careful while handling the box and clock to avoid any damage or injury.
Altre 2 persone hanno completato questa guida.
Un commento
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
