Salta al contenuto principale
Epson VS250 Speaker Replacement
Cosa ti serve
  1. Epson VS250 Speaker Replacement, Shell: passo 1, immagine 1 di 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
  2. Epson VS250 Speaker Replacement: passo 2, immagine 1 di 1
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Speaker Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
  4. Epson VS250 Speaker Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
  5. Epson VS250 Speaker Replacement: passo 5, immagine 1 di 2 Epson VS250 Speaker Replacement: passo 5, immagine 2 di 2
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
  6. Epson VS250 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the front cover from the projector by pulling it off of the device.
  7. Epson VS250 Speaker Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
  8. Epson VS250 Speaker Replacement: passo 8, immagine 1 di 1
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
  9. Epson VS250 Speaker Replacement, Speaker: passo 9, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws holding the speaker in place.
  10. Epson VS250 Speaker Replacement: passo 10, immagine 1 di 2 Epson VS250 Speaker Replacement: passo 10, immagine 2 di 2
    • Pinch and unplug the speaker cable from the motherboard.
    • Remove the speaker from the device.
Conclusione
Warren Cutlip
Membro da: 09/28/21
604 Reputazione
5 Guide realizzate
Clemson, Team 4-2, Hunter Fall 2021 Membro di Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 141
